Dean83169's avatar
Dean83169
Altice One
CAn someone help me. I bought the Orbi RBK50 and I have Altice one through optimum. I have 3 cable tv boxes that have the WiFi built in to them along with 4 Ethernet ports on the back.
pluggin the new router into the back says it’s  connected but will not let it see the internet. Is there anyone that can give me steps to fix this if possible?
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem leaving it in router mode and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • Dean83169's avatar
      Dean83169
      I have the Sagemcom DGCI384. I have to call my isp which I think they want me to pay a premier tech service because it’s not one of their devices. Wondering since it’s a cable modem if another option would be to split the service before it comes to my house and add a cable modem so I would have 2 services and not be going through their modem.
      • FURRYe38's avatar
        Another suggestion would be to find a modem only device that your ISP supports. Find something with out a built in router with the modem. Just a modem only.
        Good Luck.
