Vanyel
Mar 27, 2018Aspirant
Android phones losing wifi connection when switching between RBK50 and RBS50
Hi all, Pretty much as described in the subject. My android phone, Sony Xperia XZ Premium with Android version 8.0.0, keeps dropping wifi connection when switching between the Orbi Router and Sat...
Vanyel
Apr 21, 2018Aspirant
Hey guys, thanks for all the advice. I have tested that the issue is indeed in the Android phone as my iPhone works fine. Suspect this must be somehow linked to Android oreo.
- UlairiApr 23, 2018Luminary
I’d also recommend a factory reset. That fixed a speed problem for me.
However, it could be something different. Although my RBK50 setup is rock solid, I have similar issues with a wall plug satellite. Per post #7 of this thread, I’m pretty sure it’s a hand-off problem between the router and the sat.
