alg42's avatar
alg42
Guide
Apr 04, 2017
Anyone have sucess setting up Chromecast on ORBI in guest mode
ORBI system in router mode.
Has anyone gotten a chromecast to work on the guest network without selecting "Allow guests to see each other and access my local network"?
The system is set up in a mixed use facility and we want guests to be able to use the WIFI and a Chomecast but not to have access to the PCs that are on the network.
Any suggestions?
  • You can't have your cake and eat it, too.
    Chromecast is by definition peer-to-peer...if the peers can't talk, nothing useful is going to happen.
    Rodney
    • alg42's avatar
      alg42
      Guide
      Thanks for the response.
      Is there any news on progress toward splitting up the settings for:
      and
      access my local network.
      I really don't understand how selecting that setting is any different than not having a guest network at all.
        and
        You're right, it is confusing that the 2 options are combined as one.  The difference between checking this option and not having a guest network at all is that you don't give out your primary wifi password to your guests so you are free to change the guest wifi password between guest visits without having to also reconfigure all your home devices.
    • alg42's avatar
      alg42
      Guide
      Rodney,
      I am starting to see the wisdom behind your response.
      Orbi system is really nice experience from the clientele side of things (appears as one network, good handoffs, etc) but the backend is not super configurable.
      Planning on going to AP mode and putting a wired router in to manage traffic and security. Hopefully this will give the best of both worlds.
      • rhester72's avatar
        rhester72
        Virtuoso
        Good plan in general, but be aware that as of the time of this writing, guest mode isolation isn't working properly in AP mode (it results in guests having no connectivity at all).  That's been the case for a couple of past releases, hopefully it will get fixed in the near-ish future.
        Rodney
  • Guys chromecast has a guest mode just enabled it. Guest do not have to even connect to your network to do it. It uses sound
    • alg42's avatar
      alg42
      Guide
      May work for some. That was one of the first things that I tried. Personally I could never get that mode it working properly. I don't have any notes on what the issues were but it didn't solve my problem.
      • Carnea's avatar
        Carnea
        Tutor
        Thank you both for your answers ! I'll look into the idea of your router.
        I'll give another try at the guest mode, but until now I couldn't bring it to work at all...
