alokeprasad
Nov 28, 2020Mentor
Anyone using Ring Doorbell Pro and Spotlight cams with Orbi RBK50?
I'm considering buying an Orbi RBK50 (AC3000 tri-band) for use w my Ring video doorbell pro and spotlight cams.
I see people having issues with the Ring devices trying to connect to the wrong band (5 GHz instead of 2.4 GHz) and failing.
Is anyone here using Ring devices with the Orbi system?
Any tips/tricks in doing that successfully? I searched here and found old posts describing using Telnet and changing Orbi settings. Is that needed with the latest Orbi firmware?
Ideally, no tricks would be needed and the Orbi would automatically use the 2.4 Ghz bands w the Ring devices. Does it?
Thx.
Aloke
PS: I'm currently using R9000 X10 but it is having difficulties reaching devices to the back of the house... And some issues with slow connections on the 2.4 Ghz bands. I'm hoping that the RBK50 would be more reliable.
alokeprasad wrote:I'm considering buying an Orbi RBK50 (AC3000 tri-band) for use w my Ring video doorbell pro and spotlight cams.
Is anyone here using Ring devices with the Orbi system? People post all the time about success with Ring products, which makes the situation hard to understand. The people who post about problems are not imagining them.
Any tips/tricks in doing that successfully? I searched here and found old posts describing using Telnet and changing Orbi settings. Is that needed with the latest Orbi firmware? Splitting 2.4G and 5G bands should not be necessary. Plug, the newest RIng doorbells support both 2.4G and 5G bands.
The issue is not Orbi "using" bands. There seem to be two common problems (1) completing the device set up, and (2) opening a camera for "Live View".
You are entirely right to be aprehensive.
- alokeprasadMentor
Thx. for the reply. My Ring devices don't support 5Ghz.:smileysad:
I'm hoping for some success stories with Ring and Orbi. I have been using Netgear routers, unmanaged switches, and even old ReadyNAS (from Infrant days) for decades. So I can set these up and update the firmwares etc.
Has anyone done that recently? Did the Ring devices connect and function? Did they stay connected?
If not, how did you make things work?
IMO, Netgear should have a "advanced" setting that allows users to assign the frequencies to select devices that are finicky about connections. But I cannot depend on that happening.
A Fix: https://community.netgear.com/t5/Orbi/Best-Performance-for-Ring-Devices-Orbi-Config-Settings/m-p/1768448#M64620
https://community.netgear.com/t5/Orbi/Need-some-help-with-Orbi-and-Ring-Doorbell-2/m-p/1671059/highlight/false#M46565
https://community.netgear.com/t5/Orbi/Ring-Doorbell-2-and-Orbi/m-p/1685149/highlight/true#M49058
https://community.netgear.com/t5/Orbi/Orbi-and-Ring-products-issues/m-p/1709487/highlight/true#M52996
- Kygord800Aspirant
Im using an inexpensive RBK13 Orbi system with our full Ring system(3 flood, 2 spots, doorbell, security system with a ton of sensors) and it works GREAT!!!
It did NOT work great when it was running off my COX modem/router/wifi.
Putting in the Orbi was the best decision made regarding my Ring system.
