ShadowHead
Jun 16, 2019Tutor
AP Mode Vs Router Mode - DHCP Passthrough
Perhaps this was covered many times already. If I missed the post or failed to find the answer, my apologies.
I am curious if ORBI RBR50 offers any option to pass DHCP requests from connected wireless clients over to the main router while operating in ROUTER Mode.
Setup:
ISP Modem -> Home FreeBSD Firewall -> ORBI RBR50.
I wish to keep the RBR50 in Router mode in order to enjoy some of the filtering capabilities. However, I do not wish to use the DHCP Server within the RBR50 but rather, allow connected devices to get the IP address directly from the freeBSD Firewall (DHCP Passthrough). Is there any way to get this to work in this manner ? Whish to avoid double NAT.
Using the web interface, on the Advanced Tab, LAN Setup, there is a check box, "Use Router as DHCP Server". Uncheck that box.
Thanks CrimpOn. However, thought that just mean it would turn off DHCP Server.... meaning it expects clients to have static IP addresses hard coded. I dont believe I get actual DHCP passthrough. Will verify.
ShadowHead wrote:Thanks CrimpOn. However, thought that just mean it would turn off DHCP Server.... meaning it expects clients to have static IP addresses hard coded. I dont believe I get actual DHCP passthrough. Will verify.
Please post what you find. I would try this myself, except my new modem is "only a modem." DHCP Discover is a broadcast packet, where the "to" MAC address is FF:FF:FF:FF. I would think that the Orbi is supposed to transmit that packet out every link.
