evil_mike
Mar 01, 2019Apprentice
Armor on Orbi questions (activation issues and another question)
Hey gang,
Just upgraded my Orbi to the latest firmware and, when I try to activate Armor, I keep getting the error message "Device is off-line" (see screenshot). What I've done so far: 1...
WRSORBI
Mar 01, 2019Luminary
Same issue trying to activate Armor. RBR50 Firmware V2.3.0.32. ISP is Comcast and modem is DOCSIS 3.1 Arris SB8200.
WRSORBI
Tried it again and Armor activation from the Orbi app worked with no problems. Fully installed.
- evil_mikeMar 02, 2019ApprenticeUpdate: I did what I said I didn’t want to do and factory reset my router.
Boom: Armor activated without issue. Now to test it with Circle enabled too.- FURRYe38Mar 02, 2019Guru - Experienced User
So you reset the Orbi and Armour is now working?
Boom: Armor activated without issue. Now to test it with Circle enabled too.- WRSORBIMar 02, 2019Luminary
No. I changed nothing. I simply waited about 2 hours, retried and Armor successfully activated with no issues from the IOS Orbi App.
