jmrobles
Jul 06, 2020Aspirant
ARP table changes - ORBI RBR40 and three sattelites
Firmware V2.5.1.16
2-6 times per day I see the following change in the ARP table
IP:192.168.1.250, Old MAC: ??-??-??-??-??-18, New MAC: ??-??-??-??-??-90
The ??-18 MAC address is the main router which has an IP of 192.18.1.1 not 192.168.1.250
The ??-90 MAC address is one of the sattelites which has an IP address of 192.168.1.8 not 192.168.1.250
What is ORBI doing ??
Thanks is advance for the help
Where are you seeing this report?
- In the Orbi log file?
- On a computer?
- jmroblesAspirant
GlassWire for windows network monitor
Well, this is indeed a puzzle. 192.168.1.250 does not respond to ICMP on my network (one Orbi router, one satellite).
When I attempt to ping it, the ARP requests are never answered.
192.168.1.250 is known to be an IP address that Netgear uses for configuring networking gear, primarily WiFi extenders. (Google search)
I got nothin.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerIs Daisy Chain Enabled or disabled?
Has a factory reset and setup from scratch been performed since last FW update?Set up IP address reservations for the RBS.
- jmroblesAspirant
Daisy chain is enables
Try this, factory reset the RBR and RBS. I would disconnect all other devices from the RBR and RBS. Setup the RBR first using 1 wired PC. I would disable Daisy Chain first. Then sync the RBS to the RBR one at a time. Setup a IP address reservation ON the RBR for each of the RBS. Once they are connected and setup with the RBR. Turn them OFF and place back in there remote locations. I would connect the rest of your devices and network back to the RBR. Then turn on the RBS one at a time. Then let things settle in. Check the logs. Or turn on the RBS first, then connect the rest of your devices and networking to the RBR. Check logs.
