Bmw4boy
Mar 01, 2017Tutor
AT&T Uverse Pace 5268AC in DMZ+ With Orbi ... help please
So I've been struggling with this for about two weeks now. I want to be able to use Orbi as my router with my ATT suplied Pace box because the Pace doesn't support UPnp or NAT lookup (or so people sa...
st_shaw
Mar 01, 2017Master
This is really an issue with your Pace 5268AC router. You want to put the Pace into bridge mode, if it supports it, so the Pace will pass the WAN IP to your Orbi in router mode.
See if this works:
https://wiki.sonic.net/wiki/Pace_5268AC#Bridged_mode
If that doesn't work, then Google "pace 5268AC bridge mode" and look to see what other people have done.
In any case, proceed with caution and at your own risk. :)
Bmw4boy
Mar 01, 2017Tutor
The actually doesn't have a bridge mode offically it only supports DMZ+ mode which is an IP passthrough. Essentially you're dissabling the firewall on a single devie and passing it the public IP address. Unfortunatley that's really what everyone is recommending an it's the only thing I can do. I think my problem is a bit more nuanced than that. I bet there is some seetting or something someone could see in the numbers if they looked at both of my settings page and I'm just not seeing it because I'm not that good at this stuff.
- st_shawMar 01, 2017Master
The link I posted is for enablng bridge mode on the 5268AC. I realize you might have different firmware, which does not have the same option, but did you follow the link and see if the instructions work on your device?
- Bmw4boyMar 01, 2017Tutor
Yeah it seems like a lot of thinks on that wiki are dated now that they've updated the firmware the section doesn't even exist in my settings.
Ok. Too bad.
I'd guess if you cannot get the Pace to do what you want without Orbi, and ATA&T gave you a locked down modem, and AT&T won't allow third party modems, then AT&T probably doesn't want you doing what you're trying to do!
Unless you can get around it using port forwarding, or some other workaround, you might have no choice other than going with another ISP.
