Bmw4boy
Mar 01, 2017Tutor
AT&T Uverse Pace 5268AC in DMZ+ With Orbi ... help please
So I've been struggling with this for about two weeks now. I want to be able to use Orbi as my router with my ATT suplied Pace box because the Pace doesn't support UPnp or NAT lookup (or so people sa...
JoesLeftShoe
May 10, 2017Aspirant
So I don't use the Orbi wifi system but came across this thread previously due to issues setting up my Pace 5268AC on U-Verse with my Luma system. I had to avoid the DMZ+ mode and 'Allow Individual Applications' in order to get my Plex server and Tablo DVR to be accessible from the outside. I set up each port by Application name and then assigned those applications to my Luma Router. For whatever reason, simply passing through my external IP address via DMZ+ didn't solve the problem.
Hopefully this helps someone.
