Bmw4boy
Mar 01, 2017Tutor
AT&T Uverse Pace 5268AC in DMZ+ With Orbi ... help please
So I've been struggling with this for about two weeks now. I want to be able to use Orbi as my router with my ATT suplied Pace box because the Pace doesn't support UPnp or NAT lookup (or so people sa...
bhoriuchi
Jun 14, 2017Aspirant
I was running into this issue with my new Orbi router on uverse until i read the blurb on DMZ Plus mode that says the "computer" needs to be rebooted. So i enabled DMZ Plus mode and rebooted the orbi and everything started working (i already had all my port forwarding set up in the orbi).
- waynealightAug 28, 2017Apprentice
i have that same pace router aswell. dmz+ mode, then setup port forwarding and triggers for the port range you need. my camera system is what i deal with. even though orbi supports upnp, which allows the cameras to get online, i cant view them when im on the orbi network until i setup port forwarding manually. added the range that covered the cameras and worked immediatly. dmz+ is the only way to get those ports past the uverse router. manually configuring wont help. rebooting the computer after dmz+ will force the ip change.
