Retired_Member
Nov 03, 2019Attached Device Rename not working
Hi All,
I have contacted Orbi support with this one but they don't seem to have the answer I'm looking for.
They have told me to try using the WEBUI Advanced Security -> Access list -> Not working
Advanced -> Setup -> Lan rename device -> Partly working.
For some reason some of the device are renamed and some not.
Anyone else having this problem?
I'm using the latest firmware and I have reseted to factory default 3 times to see if this helps but it has no impact on the problem.
I don't think it's a hardware issue because some of the devices are renamed.
Firmware: 2.5.0.38
Toube
- Retired_Member
Lots of posts here about this subject.
Your problem is Firmware: 2.5.0.38
Roll your firmware back and STOP doing manual updates.
its a known issue with the 2.5.0.38 firmware.
https://community.netgear.com/t5/Orbi/Orbi-Firmware-Update-2-5-0-38/td-p/1814184
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Device-Names-not-Saving/m-p/1814717#M73473
You could roll back the firmware or wait for the newest firmware update to see if it fixes it.
- Retired_MemberThanks.
Yeah that was my assumption also.
Well not such a critical bug still something many would like to have working.
Going to wait for Netgear to release a new firmware that fixes this. Btw how often are the firmwares updated?
Toube- plemansGuru - Experienced User
there's been 29 updates since it was released. So quite frequently in comparison to other routers.
Care to give v40 a try? Looks like one user said the naming of devices seems fixed for him.
Retired_Member wrote:Hi All,
Firmware: 2.5.0.38
Toube
- kuno2501Guide
Having same issue since the latest update Router Firmware Version V2.5.0.38
Attached device name got messed up and cannot rename some of them, also cannot change access control of some of the attached devices!!
This update is terrible- FURRYe38Guru - Experienced User
Give v40 a try and see if this resolves this for you. Others have reported v40 fixed it for them:
I recommend doing a factory reset and setup from scratch on the RBR after updating FW. If this doesn't work for you, revert back to v30.
kuno2501 wrote:Having same issue since the latest update Router Firmware Version V2.5.0.38
