Jroach's avatar
Jroach
Luminary
Mar 14, 2018
attached devices shows devices that are physically wired as connected via wireless
Having issues with network "thrashing".
General: I put in Orbi a few months back.  Continuosly troubleshooting things that I can't quite figure out if I'm having multiple device issues or an Orbi issue.  The satellite has already been replaced.
Problem: One specific issue I see is that I have a server that is wired directly to Orbi.  When looking at attached devices it shows as "2.4Ghz Guest".  Wireless is turned off at the server and I don't even have the "Guest" network enabled.  If I reboot Orbi it will show "wired" for a few seconds then switch to 2.4Ghz Guest.
Once I can figure this out I want to try and determine why some devices show "2.4Ghz guest" vs "2.4Ghz".
  • Quick edit/addition:
    When the server shows up as being connected "2.4Ghz Guest" it is attached to the satellite not the router.
  • FURRYe38's avatar
    What FW version is the router system using?
    Maybe something that will be changed in next FW update.
    • Jroach's avatar
      Jroach
      Luminary
      Good question.  I am on 2.1.2.18.
      I have heard that this version is a BIG problem but I can't figure out how to go back to the previous version to see if my issue is related to firmware.
      • Jroach's avatar
        Jroach
        Luminary
        I found the old version of Firmware.
        Downloading now and will install/report back.
  • FURRYe38's avatar
    Good to hear it's working better.
    Enjoy.
  • FURRYe38's avatar
    Hope next update will be good.
    Enjoy for now.
