johnny5126
May 08, 2019Aspirant
Backhaul Broke?
Ever since updating from 2.3.1.44 to 2.3.1.60, my ethernet backhaul no longer connects. It only shows 5G backhaul. This happen to anyone else?
If it shows 5G then it's working. Unless your RBS is wired?
Has a factory reset and setup from scratch been performed on the system?
- johnny5126AspirantI have one RBR50 connected in the WAN port going to a switch, and a cable going from the switch to a port on the RBS50. Looking at the connected devices in the past showed wired, but now it shows 5g.
What is the Mfr and model# of the ethernet switch in the configuration.
This is ethernet back haul.
Is Daisy Chain enabled? It should be disabled when ethernet connected between RBR and RBS. Under Advanced Tab/Advanced Settings/Wireless Settings
