jdubyas
Jun 04, 2017Tutor
Bad iOS/Apple Connectivity (solved) and Slow Speeds - Orbi RBR40 - FW v 1.10.1.2
I have owned the Orbi RBR40 home wifi system for approximately 3 weeks. Within the first 30 seconds of being connected I ran a speed test and it showed 150mbps up/down immediately after a ran a subse...
samsamsamsam
Jun 05, 2017Guide
I'm not criticising you jdubyas, thank you taking the time to write up your workaround.
What I don't understand is why this is marked as SOLVED. Not using a router as a router is not exactly a solution.
