jdubyas
Jun 04, 2017Tutor
Bad iOS/Apple Connectivity (solved) and Slow Speeds - Orbi RBR40 - FW v 1.10.1.2
I have owned the Orbi RBR40 home wifi system for approximately 3 weeks. Within the first 30 seconds of being connected I ran a speed test and it showed 150mbps up/down immediately after a ran a subse...
MachineLearner
Jun 10, 2017Apprentice
jdubyas,
If you want / need to continue to use your ATT fiber router, wouldn't you be better off with simple wireless access points, rather than a 2nd router and satellite? Can you still return the Orbi? Looks like you have the option of running ethernet cable running to your Orbi satellite, based on your initial write-up. If you can connect the WAPs to your ATT router via ethernet cable, you coud go with top-rated Unifi wireless access points and probably get higher performance at less cost.
js
