Dogen
Jan 26, 2019Aspirant
Barn WiFi question
I have an Orbi AC3000 base station and one indoor satellite in my farm house. This works great. I want to have wired and WiFi in my barn. (Too far away for the Orbi to reach.) So I’m installing an ...
CrimpOn
Jan 27, 2019Guru - Experienced User
The short answer is "yes". Orbi allows you to "Daisy Chain" one satellite off of another. The link between the two satellites can be 5G wireless or ethernet. As far as the two satellites are concerned, how ethernet gets from one to the other is not apparent. It could be a single cable.... OR, it could be a link of some kind.
I believe there have been other inquiries in this forum, specifically about "barns". Might be useful to search the forum.
Dogen
Jan 27, 2019Aspirant
Thanks, exactly what I was looking to know.
I did read the other barn threads before asking.
Later on I found a NetGear article on extending Ethernet which showed a picture of what you described except with all Orbis using wired connections. Logically it seemed like it shouldn’t matter whether the base station is wired to the first satellite or WiFied to it. But I prefer to get confirmation before purchasing...
