Naor1999
Apr 03, 2019Aspirant
Best way to setup RBR50/RBS50 with Nighthawk x8
Does anyone know the best way I can hook up the following equipment (wirelessly) for best signal output?
I have the orbi rbr50 router, orbi rbs50 satellite and the nighthawk x8 ac5300 router.
What is the Mfr and model# of the ISP modem the NG router is connected too?What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
The R series router can only run in Router, AP or wireless bridge mode. It can be connected as a wireless bridge with the Orbi if you have wired devices to connect to it when in this mode.
I have the orbi rbr50 router, orbi rbs50 satellite and the nighthawk x8 ac5300 router.- Naor1999AspirantWhat Firmware is currently loaded?
- ORBI - v2.3.1.44
- X8 - I don’t know how to access it....
- Orbi is connected to “Arris 6183”
- 50’ in my home.
- I’m not sure what any of those modes are. For me, it does not matter how the 3 units are hooked up. Whichever works best will work for me.
- Chuck_MMentor
"The Best" is a bit vague.
What do you use your network for?
Is your location big? Small?
Regardless of above, you will have to decide if you want your routing functions done by the nighthawk router or the Orbi. You cannot have both in Router mode.
If you choose Orbi, there may not be a reason to even have the Nighthawk on your network.
If you choose the Nighthawk, you will need to configure Orbi as an Access Point (AP) and put it in that mode so that the routing functions are disabled.
A mesh network uses powerful radios on several frequencies. It doesnt make any sense to have both WIFI signals from the Nighthawk and the Orbi in the same spaces. If you retain the Nighthawk, I would suggest you also disable the radios in it and only use the WIFI from Orbi. This will prevent conflicting RF signals.
- Naor1999AspirantWhat do you use your network for?
- for mixed personal and business use. Everything we have runs through WiFi. Computers, TVs, gaming consoles and several voip lines.
Is your location big? Small? It’s approx a 2500 square ft home.
- I’ll take the best recommendation offered. It doesn’t matter for me which router takes the helm. I honestly know very little about this and I’m trusting in the community for help.
- I’m doing so, both orbi units could be placed in different locations giving me an equally strong signal from 3 locations in my home? (That’s my end goal)
For that size of home, the Orbi with 1 satellite should be good coverage for the entire home. I would use the R router in wireless bridge mode as a media bridge for LAN wired devices, like a PC, or NAS or printer,etc.
- Naor1999AspirantPutting it into wireless bridge mode will enable the nighthawk to act as an additional satellite?
No, The R series routers don't support repeater or extender modes. Only router, AP which means it needs a LAN cable between the main host router and itself. Wireless bridge mode means it's only connected to the main host wifi. Doesn't provide any wireless signal for wireless devices and only LAN cable devices can connect to the back of the unit when in wireless bridge mode.
Couple of suggestions.
ISP Modem> Orbi RBR>RBS<R router wireless bridge mode connected to the SSID of the Orbi.
ISP Modem>R router in router mode with it's wifi disabled>Orbi RBR configured for AP mode<RBS connected to RBR. You could have the R routers wifi enabled running on a different SSID name and different channels in router mode. Maybe problematic should something happen. Can be done though. You would have two SSIDs to pick from.
- SnapDadAspirantHelpful thread, thank you.
Question on the 2 suggested architectures:
ISP > Orbi (wifi) < X8 (wireless bridge to Orbi SSID)
ISP > X8 (wifi off) > Orbi AP (wifi)
Would either of these configurations be able to take advantage of X8's link aggregation for 2x NIC NAS ? *since Orbi doesn't support LACP*
Thanks !- FURRYe38Guru - Experienced User
No. LAG on the R9000 is only for LAN devices that support LAG, i.e. NAS or LAN switches.
