hamz1k's avatar
hamz1k
Follower
Oct 07, 2018
BLINK XT - LIVE VIEW
Hello,
I recently have upgraded my router and WIFI system by purchasing the Orbi WIFI system to replace my Linksys router that wasn't giving enough coverage.
However, since changing over to my new Orbi system - i am unable to get my Amazon, Blink wireless CCTV cameras to push a live feed to me.
I've seen some previous posts of the BLINK doorbell giving issues, so i can only presume Blink has the same problems.
Ideally,  i would love a fix or a workaround. Any ideas? Thanks!
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    I would contact the Mfr of these cameras to seek additional help and information as well. Maybe some compatibility issues.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • sb9900's avatar
      sb9900
      I have the same question.  Anyone have an answer?
      • FURRYe38's avatar
