Whdj's avatar
Whdj
Bought used orbi
Hi, when I go to security in the app, it says the unit is still registered under previous owner and I can't login to netgear armor. How do I change this?
  • CrimpOn's avatar
    CrimpOn
    You can try doing a Factory Reset on the router and then set it up with the web interface. (have nothing to do with the Orbi 'app'.)
    https://www.youtube.com/watch?v=cMw4ePACgc4
    This is the sort of thing that I have never found a mechanism to deal with on the Netgear web site.  What some people have done is contact one of the forum moderators by sending a private message to their screen name (click on screen name and then select private message Blanca_O
    Explain the situation, including serial number and how it was purchased, how to contact you, etc.
  • You can return the Orbi Pro WiFi 6 to its factory settings. Use the end of a paper clip or a similar object to press and hold the Reset button located on the back of the Orbi for at least seven seconds. The Orbi resets and returns to the factory settings.
    MyCCPay
    • Whdj's avatar
      Whdj
      That does reset the unit, but unfortunately doesn't apply to the netgear armor feature that's online
      • FURRYe38's avatar
        YOu may need to contact NG support and ask them for help and information regarding Armor. After the reset, just don't enabled Armor.
        If you want Armor, it should allow you to setup a new account. Something to ask NG support about.
