Toughguy5's avatar
Sep 03, 2021
Bridge mode fog Comcast
Does my Comcast modem need to be put into bridge mode ? Right now it’s not and it’s picking up devices in my home the Orbi should be pickup. I was told by Netgear personnel to remove the bridge mode of the Comcast modem, and since then I’ve been having problems. Right now the Orbi is in AP mode and picking up devices so is the Comcast modem picking up devices. I just need to know if I need to put the Comcast modem back in bridge mode to let the Orby do its job as a router with the satellites. Thank you.
  • CrimpOn's avatar
    CrimpOn
    At least one of the devices must be in router mode, either the Comcast, the Orbi, or both.
    The network simply cannot work correctly with no router at all.
    Two routers will work, but can lead to problems in specific situations: https://kb.netgear.com/30186/What-is-Double-NAT
    Many Orbi features are available only when the Orbi is in router mode, so most customers tend to put their ISP (Comcast) modem into bridge mode and let the Orbi be the only router.
    • Toughguy5's avatar
      Toughguy5
      Guide
      Ok, I now will put the ISP Comcast modem in bridge mode and put the Orbi back in router mode. This should fixe the problem I am having. I don’t understand why I was told to take the ISP modem out of bridge mode ? I was screwed from day one, thanks netgear.
      • CrimpOn's avatar
        CrimpOn
        If you had told me that the Orbi was in AP mode and you wanted it that way, I  would have told you that the Comcast device had to be in router mode. I sense a miscommunication.
        Glad that it is working for you now.
  • FURRYe38's avatar
    If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
