creaky
Nov 19, 2017Star
Brief magenta then long blue light on RBS50 satellite
Several times last night the RBS50 satellite would flash magenta briefly and then go to blue for a few minutes before shutting off the lights completely. I'm still getting a connection on the satelli...
Retired_Member
Nov 19, 2017Move the sat closer.
- creakyNov 20, 2017Star
The position of the router/satellite had not changed since the setup of the system so I tried something else that worked: Rebooted the satellite only and resynced it with the router; now speeds for clients connecting to the satellite are back.
- Retired_MemberNov 20, 2017
The latest branch (2.0.x) changed the range for the sats, significantly shortening it..
