cypma
Jan 04, 2021Aspirant
broadcasting signal to my shop - rbr50
I am wondering if any one has a suggestion for hardware that I could connect to an Orbi satelite to broadcast the signal across the driveway to my shop where an antenna could capture it and pass it to another Orbi satellite. I am currently set up in the house with wifi daisy chain and I have no complaints with the way it works.
What is the distance from the house to the garage area? Anything over 50 feet will be iffy or problematic at best. If you can run a buried CAT6a cable between the house and garage, then you can place a RBS connected via ethernet in the garage area. RBS40v would be suggested.
cypma wrote:I am wondering if any one has a suggestion for hardware that I could connect to an Orbi satelite to broadcast the signal across the driveway to my shop where an antenna could capture it and pass it to another Orbi satellite.
It would really help to know (a) the distance between the existing Orbi satellite and this "shop", and (b) the composition of the shop walls (i.e. metal ('bad') or wood frame construction ('better')).
- cypmaAspirant
Thank you for your suggestions. After reading the comments it dawned on me that I hadn't even bothered to check if there was signal in the shop. I have a medium strength signal in the shop, and using my phone I was able to get 150mb download using the xfinity speed test. The distance between the two builidings is about 65'. Fortunately the satellite sits in front of a large window and the satellite that will be in the garage will also be in front of a window. I also appreciated the suggestion to pick up the alexa capable satellite. It is much less than a rbr50 satellite.
Curt
Hopefully that should work for you.
