greenkaczka's avatar
greenkaczka
Follower
Mar 30, 2020
BRS_wanlan_conflict.html with orbi - and connecting to webpages with often 404 (page exists)
ATT modem (uverse)
Orbi.
connect the orbi to ATT directly per instruction.
When my Orbi system is used I often get a pop-up message which asks for  login information to websites, or message that says no such webpage exist
The web adress is followed by - BRS_wanlan_conflict.html
It prevents me from using certain webpages.
FOUND NO SOLUTION ON COMMUNITY.
  • FURRYe38's avatar
    Your ISP modem will already have a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    greenkaczka wrote:
    ATT modem (uverse)
    Orbi.
    • leuchtag's avatar
      leuchtag
      Couple of options,
      greenkaczka wrote:
      ATT modem (uverse)
      Orbi.
      Thank you!!!!!!!!  Following the Orbi manual instructions on setting the Orbi router to AP mode SOLVED THE PROBLEM. The hardest part was remembering my password to gain admin access my Orbi router -- I had to reset the password with the serial number of my Orbi Router after several failed attempts.
      • FURRYe38's avatar
        Be sure to write down important information for safe keeping and remembering. :smileywink:
        Glad you got it working.
        Please mark your thread as solved so other will know.
        Enjoy. :smileywink:
  • CrimpOn's avatar
    CrimpOn
    greenkaczka wrote:
    When my Orbi system is used I often get a pop-up message which asks for  login information to websites, or message that says no such webpage exist  The web adress is followed by - BRS_wanlan_conflict.html
    Would it be convenient for you to post a screen shot of this message?  (i.e. make a screen capture of the message. save it to a PNG or JPG file.  then attach it to a message.)  If I read the Orbi web pages correctly, there should be an IP address included in the message.
  • greenkaczka wrote:
    ATT modem (uverse)
    Orbi.
    This happens when your ATT modem is a router and your Orbi is also a router, causing the Double NAT issue FURRYe38 described.  You just need to put your Orbi in Access Point (AP) mode, so it provides just your wireless network, and leave the router function to your ATT modem: https://forums.att.com/conversations/att-fiber-equipment/brs_wanlan_conflict/5e728051c17a064135f077a4
    From FURRYe38's reply here are the instructions to configure your Orbi in AP mode:
