hookalot
Jan 02, 2018Tutor
*BUG* 2.6.1.16 SSID Name Character Limit Change
Count me in as one of the folks whose system was auto updated from firmware 2.0.0.74 to 2.1.1.16. I'm also experiencing from the various other issues reported, but wanted to touch upon this particul...
hookalot
Jan 03, 2018Tutor
Thank you for testing.
I found this additional post today, regarding the use of "$" in the password field.
https://community.netgear.com/t5/Orbi/Orbi-RBR50-2-1-1-12-Wifi-Password-issue/m-p/1476890#M19946
Made me rethink perhaps character length is not the real root cause here, instead the use of the "$" character in the SSID or password field is.
DarrenM
Jan 04, 2018Sr. NETGEAR Moderator
We have a fix for this issue in the new beta firmware that you can find here
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/m-p/1476960#M19962
DarrenM
- javasmithJan 04, 2018Tutor
Nope. I upgraded to 2.1.2.10, and password bug is still there. I have a 63-character password containing random ASCII text including upper & lower case letters, numbers, and symbols. On the first $ character in my password, the string "wl_wpa2_psk " [without the quotes] replaces the $ and the entire password is appended in its entirety after the string (without any further string substitutions). This doesn't seem to have been an issue for versions 2.0.0.76 and below. Is NETGEAR using something like Jenkins, eggPlant, or Google Test to conduct automated unit and system level testing? In the case of allowable passwords...for your nominal use cases, you'd minimally need 55 tests -- covering all of the "printable ASCII characters" across the 55 tests -- assuming a valid password length of 8..63 characters. To cover errors and exceptions, you'd need tests for pass word lengths of <8 and >63 characters; passwords that contain non-printable ASCII characters; etc.
Some additional information...if I try to change the password back to the original password via the router GUI, I get a "400 Bad Request" HTML error. Trying to force the router to revert to the correct password by going through the "setup wizard" again didn't work. Trying to use a backup settings file from version 2.0.0.76 that I made before the 2.1.2.10 upgrade looked like it was going to work. The password field in the router GUI reverted back to the original correct password. However...none of my network devices were able to connect. So...I did a hard reset on the router and satellite and manually downgraded to 2.0.0.76...but I've gotten pretty efficient at doing that. :smileyhappy: Is there anyway I can Telnet into the router and manually set the password?
