Kellybwoods's avatar
Kellybwoods
Can’t detect network when setting up orbi
This isn’t a new Orbi. I’ve had it for about a year. WiFi stoped two nights ago. Called internet provider. All fine on that end. Thought it was the modem. Got new modem but the problem continues. I can’t pull up the orbi network when setting up the orbi. We have no WiFi. Did the orbi die after a year? Why can’t it detect the network? I’ve done all the things such as unplugging and plugging and turning off cellular data and syncing and unplugging satellites around the house and there’s simply no orbi network to connect to when setting up. It is not an option. Where is it?
  • FURRYe38's avatar
    Connect a wired PC to the back to the RBR and use a web browser to access the RBRs web page at 192.168.1.1 or orbilogin.net.
    Try a factory reset on the RBR as well. Press the reset button in back for 15 seconds then release. Walk thru the setup wizard with a wired PC and web browser.
    • Kellybwoods's avatar
      Kellybwoods
      Oh wow. Okay. It was so easy to set up. I don’t understand why it’s so difficult now. I did that reset yesterday. Will try again and try to find cable to connect a computer. We’re MAC. Will that still work?
      • FURRYe38's avatar
        Of course, I use Mac as well. Long time Mac user. Some macs don't have ethernet ports. This is fixed by getting a inexpensive USB to ethernet adapter in case.
