benmitchell1024's avatar
Jul 27, 2017
Can an Orbi be connected to a Comcast gateway device?
I have  a Comcast gateway device that is both a router/modem.  Can I hook up an Orbi to the gateway?
    • benmitchell1024's avatar
      benmitchell1024
      How would I hook it up?  Connect the Orbi to the Comcast gateway and just create a whole new wifi network?
      • st_shaw's avatar
        st_shaw
        Master
        Connect the Orbi RBR unit to the Comcast gateway. Log into Orbi via the web GUI and set Orbi to operate in Access Point mode. After Orbi reboots, log into the Comcast gateway, note the new IP address assigned to Orbi, Disable WiFi radios on the Comcast.
