louis00375's avatar
louis00375
Can I disable client SSID on Satellite?
Hi all, can i disable the SSID or even the radio to the client (not to the backhaul radio) of the Satellite if possible?
    • louis00375's avatar
      louis00375
      Yes, actually. On bridge is needed for my case. Should I use Orbi? Or I should use other bridge router/equipment instead?
      • peteytesting's avatar
        peteytesting
        Hero
        the orbi will still work as a bridge with its wifi enabled , not sure why you would want to disable its wifi
