Gojulas
Sep 22, 2020Aspirant
Can I do both Ethernet backhaul and Wireless?
Got a refurbished Orbi bundle off of Amazon.
- Orbi Router RBR20
- Orbi Satellite RBS20 x 2
Right now everything is set up in the most basic out of the both configuration. Router in bedroom next to the FiOS modem. One sat. on the same floor in the TV room, and one sat. upstairs.
Can I run Ethernet from the router to a switch in the TV room, and plug THAT sat. to the switch, while at the same time leave the sat. upstairs remaining completely wireless?
Ultimately I could keep the setup the way it is and STILL run Ethernet from the FiOS modem to the TV room to feed the Roku in there.
Thanks in advance for any advice!
Yes.... but.A mix of ethernet and WiFi backhaul is supported. There are reports of problems when certain switches are between the router and the satellite. IF that turns out to be a problem, I would suggest plugging the cable into one port of the RBS20 and the switch into the other port.
- MstrbigMaster
Gojulas wrote:Can I run Ethernet from the router to a switch in the TV room, and plug THAT sat. to the switch, while at the same time leave the sat. upstairs remaining completely wireless?
To avoid switch issues, you would want to run Ethernet from the router to the satellite in the TV room, then plug the switch into the satellite.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Non managed non green ethernet featured switches are recommended.
Gojulas wrote:Got a refurbished Orbi bundle off of Amazon.
- Orbi Router RBR20
