WiseSilverWolf's avatar
May 15, 2022
Can I use my Orbi RBK50 and RBS50 with Verizon's 5G Home Internet Modem/Router?
So I just switched from Comcast where I was using a Motorola SB8200 cable modem along with my Netgear Orbi RBK50 Router and 1 RBS50 Satellite as a mesh system in my house but I was wondering if I could still use my Netgear Orbi system to cover some dead spots in the house that arent covered by my Verizon 5G Modem/Router... if they work how would I go about doing the setup?
thank you
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option  #2 first...
  • Yes, make sure you get the latest firmware.
    I have and had the exact same set up as you.
    I disable DHCP then set it to passthrough on the new firmware on the 5G.. Then you need to use Port 2 on the Verizon 5G and connect that to the same port as your cable modem use to go though on the Orbi.
    I swap back and forth between Xfinity and Verizon now with no changes outside of what I plug into the Orbi as the modem.
