allir
Nov 05, 2017Tutor
Can not create a static route to single IP (Orbi 2.0.0.74)
When adding a static route to a single IP it is not applied. I'm trying to block access to certain IP's by adding static routes and directing them to the local interface on the Orbi.
I enter the IP, Subnet 255.255.255.255, Gateway 10.0.0.1 and Metric 2. I press apply but it does not. Does not show up in the list of static routes.
(10.0.0.1 is the Orbi's internal IP)
If I enter the same IP and a 24bit subnet (255.255.255.0). Press apply and it is applied and saved. Shows up in the list of static routes.
- Don't use 10.0.0.1 for the gateway. Use an allocated address on your subnet, like 10.0.0.254. Just make sure that the Orbi's DHCP server can't hand out 10.0.0.254 to any device.
- allirTutor
Doesn't work. No matter what you put in other fields, using subnet mask 255.255.255.255 does not work.
My workaround for now is using 255.255.255.252, but it's not a solution as I'm blocking addressess that I don't want to block. I want/need to be able to route a single IP.- Sounds like a bug.
