Premier79's avatar
Jul 05, 2019
Can not find Router
Recentely just bought the Orbi RBK50 - AC3000.  I followed all the steps as listed on the webpage https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite
I get up to Step 9, the Satellite has a solid blue light.  When I go to step 10, connect via wifi on the IPhone app, I receive a message stating "Router not Found." I look at available SSID, looking for mine ORBI63, and it is not listed.
I've redone the steps numerous times with the same results.  Any help is appreciated
Hardware
Netgear Orbi RBK50 with Satellite
ISP
Optimum Online
ISP Modem ARRIS TM1602
  • CrimpOn's avatar
    CrimpOn
    Just to be clear:
    Premier79 wrote:
    I get up to Step 9, the Satellite has a solid blue light. (and then goes out???)
    In Step 10, you connect to the Orbi network before running the Orbi app?  (Under "Settings->WiFi")???
    Correct?
    • Premier79's avatar
      Premier79
      Tutor
      Step 9 satellite stays lit blue
      step 10 can't connect to the network. Ssid isn't listed
      • michaelkenward's avatar
        michaelkenward
        Check that it isn't a distance thing.
        How far is the satellite from the router?
  • FURRYe38's avatar
    Factory reset the RBR and connect a wired PC to the RBR and use a web browser to set up the system.
    Hardware
    ISP
    Optimum Online
