John29466
Sep 26, 2016Follower
Can orbi be used with Netgear routers as access points?
1 Reply
hi
yes the orbi router has the ability to be put in AP mode so you can connect it to your existing router and also still use its sat , this imho would be the best way to use the orbi at this stage
