KarstenG's avatar
KarstenG
Follower
Feb 08, 2017
Can Orbi configured to act as wireless bridge
I have a RBR50 with the RBS50 setup. The Router creates a wifi network and is conected to a switch which in turn is connected to the internet gateway.
The satellite is rather far away and in turn connected to a switch as well which connects my office hardware via ethernet (aside from creating / extending the RBR's wifi network).
Question: I dont need the wifi network / RBR & RBS acting as wireless APs. The only thing I need is the Orbi's feature to powerfully bridge space where there is no chance to have a wired / ethernet connection (the backhaul is just great).
1/ Is there any way to configure the RBR / RBS so that a simple wireless bride is built that connects my remote office switch  to the IPS / the gateway-attached switch (if possible without creating a wifi network i.e disabling the access point functionality of the Orbis)? I have not found anything like this in the config shell.
2/ If yes: where do I find the settings / what needs to be done?
3/ if no: Any thoughts around workarounds (or do I have to stick to the APs turned on)?
1 Reply
  • The Orbi backhaul already acts as a wireless bridge, just as you descrbe.
    I believe if you simply turn off both the 2.4 and 5 GHz WiFi radios, then Orbi will operate as you desire.
    Advanced --> Advanced Setup --> Wireless Setitngs --> uncheck "Enable Wireless Router Radio" on both 2.4 and 5 GHz
