Bielski
May 25, 2018Tutor
Can You Attach a Gigabit Switch to am Orbi router?
I'm thinking of purchasing an Orbi RBK33 or RBK43 system for my home. One of mychallenges is that I currently have 4 ethernet lines going to 4 jacks in my house from my existing router. The Orbi ro...
May 25, 2018Guru - Experienced User
Yes, just make sure its a NON-Managed switch.
bbuyack
Sep 07, 2018Aspirant
Is there a reason you can't use a managed switch? I have this TP-Link switch attached: http://a.co/d/8EONRWp that i purchase from Amazon. (
TP-Link 24-Port Gigabit Ethernet Easy Smart Managed Switch |
- FURRYe38Sep 08, 2018Guru - Experienced User
Maanged switches seem to give problems with Orbi systems, however a few others have got them to work with the disabling of IGMP protocols, so if you don't need that procotol running on your switch, you can try it and see:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M38123Let us know if it works for you...
