Atlas2010's avatar
Apr 29, 2020
Cannot connect Orbi RBR50 to Viasat modem RG1100
Has anyone been able to connect Orbi RBR50 to Viasat modem RG1100? Please let me know settings on Orbi and Viasat. Any help appreciated.
Thank you.
  • CrimpOn's avatar
    CrimpOn
    Was trying to research and found the link to
    • Can I use another wireless router with my Viasat WiFi Gateway?
    Yes! For information on how to connect a wireless router to your Viasat WiFi Gateway, check out our article
    https://help.viasat.com/internet/articles/General/Can-I-use-another-wireless-router-with-my-Exede-WiFi-Modem
    and "oops.".  Nothing.
    Can you describe what happens when the Orbi is connected to one of the etherent ports?
  • FURRYe38's avatar
    I would contact Viasat for help and information on using external routers with there system. SAT can be picky about this. I remember having problems when I had SAT years ago.
    Be sure there modem/router isn't using 192.1681.1 for an IP address.
    If the modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Thank you.
    • Atlas2010's avatar
      Atlas2010
      Tutor
      Hello FURRYe38,
      I have the Viasat modem in Bridge Mode, but still having problems. Viasat has no idea how to set up. How do I put Orbi in Router Mode?
      • FURRYe38's avatar
        Did you power OFF the SAT modem for 1 minute then back on then factory reset the RBR and walk thru the setup wizard using a wired PC and web browser pointed at 192.168.1.1?
        Be sure your using a good quality LAN cable between the modem and RBR. CAT6 is recommended.
