Kjors
Oct 28, 2020Aspirant
cannot connect vpn l2tp, orbi satellite
Hi all,
I am have a problem with an orbi satellite. When connected to the satellite I cant coonnect to a vpn. When connected to wifi from the router itself the connection can be established. As given in the subject its an VPN based on L2tp. I am connected to the main network, not the quest.
What could be the reason why it wont work with the satellite?
Thanks,
Kjors
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.Is the RBS wired or wirelessly connected to the RBR?
- KjorsAspirant
Updated to the latest firmware, RBR 40 : V2.5.1.22 and RBW30 V2.5.0.4
ISP modem/router (ZTE Experia Box v10), set to bridge mode. Wired to the orbi router (RBR40). The wall plug satellite is connected wireless, about 10 meters (33ft).
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #2...put the modem back in to router mode and disable ALL wifi radios on the modem...
