johnniej's avatar
Jan 19, 2019
Cannot log into RBK50 router using MS Edge browser
I cannot log into my router with orbilogin.com when I use MS Edge browser.
Works fine with Chrome or if I use Internet Explorer.
I have started to use the Edge browser and kind of like it except I don't want to use it if I can't log into my router if I have to.
I had to change the IP address of the router because Xfinity uses the 10.0.0.1. But like I said I can reach the admin login page with Chrome or Internet Explorer either using the orbilogin.com or by typing in the IP address but not when using MS Edge.
I'm using Windows 10.
I also tried disabling the Firewall in Windows Defender but that didn't help.
Can you lead me in the right direction so I can solve the issue.
Any help is appreciated.
