rodstar1's avatar
rodstar1
Can't access Orbi interface at times, after reset, reboot it works then the problem returns.
I hope someone knows the solution. I can't access my Orbi at random times and have to restart the Orbi and I have reset the Orbi, it fixes the issue for a little while and the problem returns? I have tried multiple browsers and computers and have updated the firmware.
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last update?
    What browsers are you using?
    Wired or wireless when your trying to access the CBRs web page?
    Using 192.168.1.1 or orbilogin.com?
    • rodstar1's avatar
      rodstar1
      I have completed a factory reset twice, it is wirelessly and remotely problematic. This issue is on chrome, safari, opera and Firefox using MacBook Pro and IPad Pro.
      • FURRYe38's avatar
        What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
        Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite.
