mrpergo's avatar
mrpergo
can't connect new wifi6 orbi RBR750
I have an RBR 40 orbi system with 2 satellites that works fine. I purchased the WIFI 6 system RBK753 that has 2 satellites and I can't get the app to set it up. I've messed around for a couple hours unplugging and plugging modem & router and still nothing. The Orbi 45 comes up on my iphone wifi and that's it. I finally took the new system down and plugged my old one back in and it works perfect. Any help would be appreciated
    You're mixing apples with oranges
    recommendation :   Run the 753 alone and forget the app
    • mrpergo's avatar
      mrpergo
      I'm not trying to run them all together I'm replacing the old RBR40 system with the RBR 750 system
      • vajim's avatar
        vajim
        Master
        Ok.  Do it without the app
  • FURRYe38's avatar
    Orbi AC RBS are not wirelessly compatible.
    Be sure your mobile phone is connected to the Orbi AX systems wifi before trying to connect the Orbi app. Or use a wired PC or laptop connected to the Orbi AX RBR to set it up.
    Good Luck.
