ztekdesign
May 08, 2019Aspirant
Can't connect to my work VPN
Since installing the Orbi sytem I can no longer connect to my works VPN using Remote Destop. Is there something needs to be setup in Orbi for this? It works just fine using my old router or using my phone as a hot spot. Something in Orbi is blocking the connection.
Is the Orbi system operating in Router or AP mode?- ztekdesignAspirant
Orbi is operating in Router Mode and its running the latest version of firmware. The ISP is a wireless comany and they simply have a radio on the roof of my home that connects to their tower. Not sure of the hardware make or model. It works fine if I plug one of my old routers in place of the Orbi. I doubt it's my ISP or their hardware.
I contacted Netgear support and they told me I need to add a VPN service to Orbi. Isn't that only so I can connect to my home network when I am outside my home? I want to be at hom and connect to my work computer using remote desktop. Something that is very common these days. Not sure why they would tell me that.
You might try this, reconnect you old router back online. Reconfigure the Orbi for AP mode and connect it to the old router. Be sure to disable ALL wireless radios on the old router.
Does your VPN work in this configuration?
Do you have any parental controls or any security apps enabled on the Orbi currently?
- gr8shoVirtuoso
Client side VPN should work fine without any intervention on the Orbi. I have one client here using NORDVPN without any issues, and over time I expect more of the clients to be using VPN connections.
I agree it should work. I just got done speaking with Netgear support and they are now telling me that I need to engable and install OpenVPN in order to get the Remote Desktop to work. I've owned and setup hundreds of routers over the years and have never had to do this just to use Remote Desktop. Either they are telling me wrong or this device is going to be a huge problem for the average user. Something doesn't add up.
- gr8shoVirtuosoThey must be misunderstanding you. If it’s a foreign call center, they might just be reading off a flowchart.
