AzJazz
Dec 09, 2016Apprentice
Can't connect to new Orbi at 192.168.1.1 on my PC
Hi - I am having huge issues connecting to my new Orbi Configuration at http://192.168.1.1 on my main PC. I am running Win7x64 SP1. My main PC is connected to one of the Orbi Router's Ethernet ports....
- Dec 11, 2016
SOLUTION FOUND: I have Kaspersky Anti-Virus 2017 installed. This was the root of the problem.
I had previously tried disabling KAV2017 and exiting KAV2017 as part of my debugging effort. However, access to 192.168.1.1 was still blocked even when I had terminated KAV2017. So for a while, I thought KAV wasn't the problem. The clue I found just a few minutes ago was that I noticed that the "Can't access this page" browser error message changed slightly depending on whether KAV2017 was disabled (paused) or whether it was terminated. When KAV2017 was terminated, there was additional information available in the browser error message that pointed to KAV as the culprit.
When I temporarily uninstalled KAV2017, I was able to get to 192.168.1.1 again. Whew!I find it interesting that KAV2017's "protection" (if you want to call it that) was so thorough and at such a low level, that it prevented access to 192.168.1.1 even inside Virtual Machines that didn't have any Anti-Virus software installed at all. It's actually pretty impressive how comprehensive Kaspersky's protection is, except that it was undesired operation for me (and probably a lot of other folks).
When I added http://192.168.1.1 and https://192.168.1.1 to the KAV2017 Web Anti-Virus URL Advisor Exclusion List, I can get to 192.168.1.1 fine now on my main PC.
Cheers!AzJazz
murchman
Can you ping the 192.168.1.1?
DarrenM
Dec 09, 2016Sr. NETGEAR Moderator
You can also try www.routerlogin.net but if that is not working open your network and sharing center and check the top it should show your pc the router then connected to the internet make sure the router shows up as a little house so its set to home network if it does click on it then you can right click the router and view device webpage.
DarrenM
