nightfat73's avatar
nightfat73
Can't connect to Orbi's network
Just got Orbi AC2200 triband system. Tried to log in into both orbilogin.net and .com and get an error message of "You are not connected to your Orbi's WiFi network. To access orbilogin.com, your device must be connected to your Orbi's WiFi network. Check your current connection and try again."  Modem is a Netgear AC1750 WiFi Cable Modem Router.  The router is turned off.  I have completed the suggested steps for unsuccessful login multiple times.  The router's default IP addresses to do not work. All the lights are blue.
    Are you able to connect to the Orbi's WIFI before trying to log in?
    Did you try connecting with a cable to an Ethernet port on the router and then connecting to the Orbi's default IP?
      • st_shaw's avatar
        st_shaw
        Master
        OK.
        Technically, not being able to connect to "orbilogin.com" means the Orbi is not the name server for your computer. This can happen if Orbi is in access point mode and another router is runnning, or if you computer is not geeting assigned an IP address via DHCP from the Orbi.
        When you connect to Orbi, either WIFI or wired, are you able to reach the Internet OK?
        Are you running Orbi in router mode (default) or access point mode?
        Can you wire a Windows computer to one of the Ethernet ports on the Orbi router (not the yellow Internet port), run the "ipconfig /all" command, then post the Ethernet adapter section of the output? This will list your IP address, DNS server, gateway, etc.
