aalvarad's avatar
aalvarad
Cant connect using my company VPN
All works well, but when I try to establish a VPN with my company then it doesnt work. I am simply not able to connect to my company via VPN. That is deal breaker.
Help
  • CrimpOn's avatar
    CrimpOn
    Many users report using VPN with the Orbi system.  Perhaps if you identify the specific VPN others can comment on how they got connected.  Ordinarily the brand of ISP modem is something to ask about, but the CBR40 includes a cable modem in the router, so you (literally) have no ISP device, correct?
    • CrimpOn's avatar
      CrimpOn
      p.s. Is this VPN connection on a Mac or Windows platform?
      And, it works successfully when connected to other networks?
      • aalvarad's avatar
        aalvarad
        Windows platform
        and all works well except when I try establish the VPN to connect to my company network
    • aalvarad's avatar
      aalvarad
      My Orbi is only a router, it doesnt have a modem integrated.
      The brand of my modem is Arris SB8200
      • CrimpOn's avatar
        CrimpOn
        Thanks.  I was confused by the signature line that mentions "CBR40", which is the Orbi with the included cable modem.
        The Arris SB8200 is "only a modem", which removes a number of possibilities.  (Good)
        My approach would be to attempt to isolate the problem to either the PC or the VPN.
        If this is a Windows laptop, I would attempt to connect from some other WiFi system.  (Desktops make that impractical.)
        Another test is to connect to some other VPN.  All of the popular VPN's offer "Free Trials", that can be cancelled immediately.
        The Windows firewall is a constant concern. We often see posts that "The Orbi port forwarding doesn't work," when the issue is that the Windows firewall is blocking connections.  If we knew which VPN software this is, maybe the User Manual offers suggestions about troubleshooting.
