fury88's avatar
fury88
Star
Aug 14, 2021
Can't reset security questions
Hello all,
I can't seem to reset my security questions. I've tried 3 different browsers and when I hit apply it does nothing. I've logged out and logged back in and they are the same questions I set up. Am I not allowed to change them?
The odd thing is when I forget my password and go to reset it, these questions come up and I answer them correctly but it always says they're wrong. Thankfully, I've been able to remember the password eventually.
-Matt
  • fury88 wrote:
    Ugh. Ok, thanks for the reply. So do I lose any settings if I backup and restore afterwards? Resetting is such a pain and takes the internet offline for 30 mins. Never a good time to do that in my household! đŸ€Ł
    Yes, a Factory Reset erases all settings.  It is a struggle to find a time for this that will not affect the family.
    I just reset the security questions on my Orbi.  The key step is that the new password fields must be filled in.  When I tried to change security questions without entering a new password, they did not "take."
    I did not actually change the password.  I entered the original password into both of the new password fields.  What matters is that there is something in those input fields.
  • plemans's avatar
    You could try a simple factory reset and reinstall.
    then during setup, you can set the questions you want.
  • fury88 wrote:
    Hello all,
    -Matt
    I think reset will work. 1st reset or formet it and then reinstall it . Hope it will works.
    • fury88's avatar
      fury88
      Star
      • CrimpOn's avatar
        CrimpOn
