Bambang
Feb 02, 2018Follower
Can't See my 5Ghz Network on my RBK50
After setting up my RBK50, I noticed that using wifi analyzer and my killer wifi card, I can't see my 5 Ghz network.
Is it there or is it off?
1 Reply
- DarrenMSr. NETGEAR Moderator
Orbi uses band steering and should switch your devices to the 5ghz network when it is the best connection for the device.
DarrenM
