_Leif
Mar 10, 2018Aspirant
Can't set up smtp for eMail notifications
Moin, ich versuche in meinem Orbi System die emails Settings einzustellen. Ich habe einen email account bei all-inkl. Leider klappt es nicht da der MAilserver als Fehler (504 5.5.2 <mail-user@RBR40...
_Leif
FURRYe38 Sorry for the german, but because I crated the user with german language setting, I thought I will post in the german neatgear community...
I will try to translate, but sorry I'm native german...
When I set up the email settings for sending the protocol, I get the error "(504 5.5.2 <mail-user@RBR40>: Sender address reje" when sending a test mail. I use a mail provider with normal smtp setting, the same I also use for my brother printer. The only differem is, that the printer has an extra field for the "e-mail Adress of the printer" and the Netgear Orbi uses the mail user + @RBR40 and the smtp server want to have a fully qualified adress, not blabla@RBD40.. I was able to use my gamail account, but in this case I have to set a security level to low (not my favorite). I hope that Netgear will be able to fix that, at least when all the other bugs that forces a lot of other issues. I checked the setting via terminal sessions, but at the end I wasn't sure if there is a way to fix that via "config". Another question was if there is a way to get some more inforamtion as currently is logged in the protocol.
Thanks and sorry again for the german post,
Leif
Roamabout
Mar 10, 2018Luminary
Leif, Google translate did a pretty good job with your original post. People should try and be a bit more resourceful on a global forum.
I have not set up the email alerts on the Orbi but looking at the documentation, it indicates that the mail from address should be set to the same address that you specify as the email recipient:
6. In the Send to This E-mail Address field, enter the email address to which logs and alerts are sent.
This email address is also used for the From address. If this field is blank, log and alert messages are not sent.
- _LeifMar 11, 2018Aspirant
Roamabout thanks for your answer. No, seems the devloper did it different, as the documentation guys specified. I used the email-adress of the smtp I used. the sender is still "smtp_user@RBR40". In my case the I have to login to my mail account with a different user as the name in front for the @ in my email adress. So my email-user is something like abc4711 and my email adress is [email protected]. Maybe that is the reason. Easy solution for the netgear devs add a field in the UI for the sender adress ;-)
- st_shawMar 11, 2018Master
It works for me when I log into my email server using a user different from the email recipient.
However, the email comes through as being sent from "root@RBR50", which is not a valid email address. There's no valid domain included.
Looks like your problem is that the email server you are using is set to reject emails without a valid sender email address. This is commonly done to reduce SPAM.
You can either use another email server that does not require a valid sender address or wait for NETGEAR to change Orbi to allow you to set a valid return address.
- RoamaboutMar 11, 2018Luminary
While they are updating the system to allow user specified From address perhaps they could also add SSL and TLS support so we are not sending creds over clear text. Even my decade old crappy web cams support secure smtp authentication.
