TcOrbi's avatar
TcOrbi
Follower
Oct 01, 2019
Cbk40-100NAS
I have the Orbit CBK 40 router/cable modem with xfjnity service. It has worked flawlessly for 9 months until today when the wide signal dropped and nothing would connect.
I first called xfjnity and they said all was ok in their end, and suggested I do the basics like unplug the router/modem, reset it with the paper clip inside the small hole. I did all of which.
I’m the orbi app, it shows the device as offline. I am able to see the network name on my laptop when I try and connect and launch a webpage, but just no internet signal coming through. Any ideas? Thank you
  • plemans's avatar
    If you go to your connections page on the cbk40 (hard wire into it with your laptop) can you take a screen snip of both the upload and download?
    How about your logs? Can you post those?
    When you say nothing will connect, I'd like more details. Nothing will connect to the wireless or it'll connect to the wireless but internet doesn't work?
    Are the orbi led's doing anything (blinking/solid, colors)
    What firmware is on it?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
