kw0712's avatar
kw0712
CBR40 - Does not pass traffic from an upstream Cisco L3 Switch
I have my CBR40 connected to a L3 switch with several upstream networks and the CBR40 will not pass the traffic to the Internet.  I have static routes to all the upstream networks and I can ping everything except, anything on the Internet.  The CBR is either dropping the traffic or not performing NAT.
  • FURRYe38's avatar
    The CBK40 passes traffic from the internet thru its RG6 coax port. There is a built in modem already with in the CBK40 thus this is the interfacing service port to your cable ISP services and to the internet. All other Ports on the back of the CBR40 are LAN side ports. You can place a swich behind (downstream) the CBR40 on one of it's LAN ports, however, this should be a managed switch with IGMP protocols disabled or a non managed switch.
    • kw0712's avatar
      kw0712
      I think you misunderstood upstream from downstream. Please see the attached diagram.
      • FURRYe38's avatar
        So do you get same results with a PC connected directly to the back of the CBR40?
        Have you tried a different switch, something like a non manged switch with a PC behind the switch?
        What is the model# of this Cisco switch?
        You might ask Cisco if there is a certain configuration needed on a Gateway or Router to effect correct traffic transportation with this switch. Possible there is a configuration needed maybe on the CBR40. This is a gateway router configuration.
