Stetrekve's avatar
Stetrekve
Follower
Feb 06, 2020
changing orbi wi-fi channel
I need to change the channel of my Orbi system to move it away from a neighbor's wi-fi.  How do I get into it to change the channel?
Stephen
  • CrimpOn's avatar
    CrimpOn
    If you remember the administrative password (not the WiFi password), you can use a web browser and go to http://orbilogin.net.  There is a menu item "Wireless" on the Home Page where you can set the chanel for 2.4G and 5G WiFi.
    Please understand, all modern WiFi systems constantly scan the enviroment and adjust to find the best channel available at the time.  You may find that as soon as you "move" your Orbi, the neighbor's WiFi may move as well.
    • 4UToday's avatar
      4UToday
      When we change the 2.4 GHz Channel from 9 to 11 and click on apply button, an popup says
      "Per Wi-Fi Alliance guidelines for 40 Mhz and 20 Mhz coexistence, even if you select "Up to 400Mbps" mode, your product’s service rate might drop to 20 Mhz. This typically corresponds to 192 Mbps performance." close button.
      It takes us back to Wireless settings again. No matter what number we choose the popup keeps coming back and we can't change it. What are we doing wrong?
  • FURRYe38's avatar
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Stephen
    • Retired_Member's avatar
      Retired_Member
      The answer is found here:  Message 2 of 3
