MyopicWombat's avatar
MyopicWombat
ChargePoint and Orbi
I’m having issues getting a ChargePoint home flex connected to my Orbi network.  Their support claimed that I need to have a separate 2.4GHz network to connect to instead of a mixed 2.4GHz/5GHz mixed network.  I couldn’t find a way to do that in the setup but did try disabling the 5GHz with no success.  My next thought was to try access control to pre-add the MAC address and maybe be able to force it onto the 2.4GHz channel.  My next issue is that the MAC address listed for the ChargePoint device has 16 characters, which I can’t enter as a valid MAC address on the router.  Does anyone have any experience getting this type of device on a Netgear Orbi network?
Thanks.
  • CrimpOn's avatar
    CrimpOn
    When looking at the ChargePoint documentation on line, it appears that:
    •  the Flex works with both 2.4G and 5G WiFi, and
    • the smartphone app communicates with the Flex charger using Bluetooth.
    This leads me to think that the typical "2.4G issues" people encounter with a few products are not what's going on here.
    https://www.chargepoint.com/en-ca/products/home/troubleshooting
    It is strange that there is no error message.
    There is one other setting that might be responsible (but I think not).  If Access Control has become enabled, it can block new devices from connecting:
    I have found that technical support people vary. It might be worth making another call to ChargePoint to explain what is happening.  i.e. "the app shows the WiFi SSID.  I enter the password correctly. and then ... "nothing".  No error message.  Nothing."
    p.s. The typical "2.4G issue" users encounter is when the smartphone app refuses to even proceed to connect to the device unless the smartphone is connected at 2.4G.  (using Bluetooth eliminates this problem).  In the newer Orbi's that cannot turn off broadcasting the SSID, the technique is to temporarily provide a 2.4G network with the same credentials, perform the setup, and then remove this network.  I have both an old WiFi router (Netgear R7000) and a new TP Link 2.4G access point (under $20 on Amazon).  I have also created a Hot Spot on my cell phone.  i.e. power off the home WiFi entirely, create a 2.4G Hot Spot with exactly the same SSID/password as the Orbi, use another device to perform the setup, and then restore the home network.  Once the device "knows" the SSID/password to the home WiFi system, there is "no problem."
    Is it possible that the ChargePoint Flex cannot get a good WiFi signal because of where it is placed?  RBS30's are often located close to the floor and surrounded by furniture
    • Vladin01's avatar
      Vladin01
      I was running in to the same issue, shut off the 5G network following above and it still wouldn’t work with the 2.4 only.
      What ended up working was turning the routers off entirely and leaving it off.  Then going to my iPhone, turn off WiFi, then rename my phone name to match my home network name (NETGEARXX), then change my iPhone hotspot password to match my network password.
      Then run through the setup process and add charger to the account.  Once added, turn off hotspot/rename phone, plug router back in, Charger connected to 2.4, then went back in and turned 5G.
  • CrimpOn's avatar
    CrimpOn
    If that method fails, there are other methods that are more complicated (and were often recommended to owners of the newer AX systems before Netgear introduced the "IoT" WiFi network for the AX products.)
    • Chrissnyny's avatar
      Chrissnyny
      CrimpOn, can you post the other methods?  I tried what you listed with my new ChargePoint Flex Charger, and it still can't log in to my Wi-Fi network.  I have the RBR40 with three satellites.  All are working very well with the other connections in the house, including IoT switches.  The SSD name is there, but when I select it from the ChargePoint app, it just times out with no connection. The closest Orbi device to the charger is a RBW30. Thank you, C
  • Thanks, I had found that setting but had not tried forgetting the network on the phone.  I will give that a try.
  • CrimpOn's avatar
    CrimpOn
    The original WiFi5 Orbi products have a feature to control whether the WiFi "name" (SSID) is broadcast.
    This feature allows the following:
    • Uncheck the Enable SSID Broadcast on the 5G WiFi.
    • Click Apply at the top of the page.
    • (the WiFi subsystem will restart - takes about a minute)
    • On the smartphone which is running the Charge Point app, 'forget' the Orbi WiFi SSID.
    • On the smartphone, select the Orbi WiFi SSID, enter the password, and Connect.
      (This will force the smartphone to connect at 2.4G.)
    • Use the Charge Point app to connect the charging adapter to the Orbi WiFi.
    • After the charging adapter is connected and working, reverse the steps
    • Go back to the Orbi Advanced Wireless Settings.
    • Check the Enable SSID Broadcast on the 5G channel.
    • Click Apply.
    • On the smartphone, 'forget' the Orbi WiFi, then select it, enter the password, and connect again.
    There is a feature on newer Orbi WiFi routers to create a 2.4G only "Internet of Things" network.  That feature was never introduced to the WiFi5 product line.
  • I’m having issues getting a ChargePoint home flex connected to my Orbi network.  Their support claimed that I need to have a separate 2.4GHz network to connect to instead of a mixed 2.4GHz/5GHz mixed network.  I couldn’t find a way to do that in the setup but did try disabling the 5GHz with no success.  My next thought was to try access control to pre-add the MAC address and maybe be able to force it onto the 2.4GHz channel.  My next issue is that the MAC address listed for the ChargePoint device has 16 characters, which I can’t enter as a valid MAC address on the router.  Does anyone have any experience getting this type of device on a Netgear Orbi network?
    Thanks.
